The receivers always hear an echo from my phone, and the soud quality is bad.
I tried to change all the sound settings available, nothing works.
Anyone had same issue already ?
Yeah it's my 3rd Z2 mate. I live in Glasgow why do you ask?
Hi there,
after testing for a long while it seems to me that the call quality depends on how I hold my phone.
If I have it between shoulder and ear - to have the hands free - the quality is really bad. Echo/Metallic sound on the caller side and poor quality on my side.
A nearly good quality for me and the caller is achieved by holding the phone only at the bottom without touching the backplate.
Maybe you others with the sme issues can test this solution.
If this workaround is approved by other users, there is a problem with the mobile antenna maybe.
Best Regards
arni
P.S.: All tests were done with noise cancellation enabled and disabled.
Can someone from Sony give us an official reply on what is happening on this issue? I rang sony support again and they want me to post my 1 week old z2 to be checked out by them. I use my phone for buisness and what am I supposed to do for 7-10 working days without a handset? I am getting really annoyed at this, should have not bothered. help and aknowledgement from Sony has been rubbish so far, PM'd my phone details to the sony chap on this forum but I am not sure what is going to happen. What a big dissapointment. If Sony can't sort this out I am definatley not going to bother with any of their mobile products in the future.
www.ifixit.com/Answers/View/81829/My+callers+hear+an+echo,+I+dont
This is not a new issue since every brand like Apple, Samsung, LG and Nokia users all experienced this problem. However, it's very hard to pin point why and how this can be overcome. Some say removing covers will help. Others believe that it has something to do with the radio station that you phone is connected to. So for those who think this is uniquely a Z2 issue, you may find the same in other phones too.
I got the same problem, poor quality while speaking, on my end I notice background noice as soon as the other one speaks. The sound levels drops now and then making it impossible to hear the other person. The other person says I am lagging alot when speaking.
This is my second Z2 in 7 days. The second one have same problems.
Also I think I have found the problem, I dont think it is the microphone or speaker of the phone. I actually think it is signal problems. I loose signal alot faster than compared to my old phone ( samsung s3 ). And even when standing still and have full 4G connection, it can suddenly drop and then quickly go to full strength again.
