Battery drains faster with Lollipop
Stenbocken
Has anyone else noticed that the battery drains faster with Lollipop, lasts now 2/3 of the time compered to before upgrade. All battery saving settings are set as before.
Tags (1)
139 REPLIES 139
profile.country.RO.title
_alexdon_
Moved your post here. Please take a look at this thread.
alexdon
Rizo1
Just wondering if anyone on Lollipop is getting same battery life as u did on Kitkat? If so, is there anything u had to do to get the battery performing as it did on Kitkat?
profile.country.US.title
Qatrium
I'd suggest that you do a PC Companion phone repair, this will do a clean installation of the latest firmware and will also wipe your internal memory.
Open PC companion -> Support zone -> Phone/tablet software update -> Repair my phone/tablet (blue link style). Follow the steps given, do not connect your phone until prompted to press volume down while plugging USB cable.
http://www.sonymobile.com/gb/tools/pc-companion/
Rizo1
Quester, thanks for that. Will that give me same Battery life as kitkat?
Qatrium
It did for me, but don't forget to backup your data.
Rizo1
Cheers Quester,much appreciated
Rekma
Haloo.. I'm user Sony Xperia Z2, since my Phone upgrade to Lollipop, Stamina of battery so fast down and my Phone feel Hot behind,,, how can I do?
Thank you
shashank11
I just saw the update centre is gone.
fotojohn
Hi all,
i repaired my phone through Pc companion , but the battery is still not working as before on kit kat.
it lasts hardly one day, with less use than i did on kit kat.
and when i do something(for example watching a video on youtube), it turns hot...
Any suggestions Sony?
Regards,
