Moved your post here. Please take a look at this thread.
I'd suggest that you do a PC Companion phone repair, this will do a clean installation of the latest firmware and will also wipe your internal memory.
Open PC companion -> Support zone -> Phone/tablet software update -> Repair my phone/tablet (blue link style). Follow the steps given, do not connect your phone until prompted to press volume down while plugging USB cable.
http://www.sonymobile.com/gb/tools/pc-companion/
It did for me, but don't forget to backup your data.
Hi all,
i repaired my phone through Pc companion , but the battery is still not working as before on kit kat.
it lasts hardly one day, with less use than i did on kit kat.
and when i do something(for example watching a video on youtube), it turns hot...
Any suggestions Sony?
Regards,
