Battery drains faster with Lollipop
Stenbocken
Has anyone else noticed that the battery drains faster with Lollipop, lasts now 2/3 of the time compered to before upgrade. All battery saving settings are set as before.
Tags (1)
139 REPLIES 139
profile.country.RO.title
_alexdon_
Nice.
alexdon
Rishnu
My handset is Sony z2 I updated lollipop. Before updating my battery backup is 2-3 days after updating its become reduced backup and shorter to 1 day.please give any solution.
Bearings
Ridhnu, please read from page 1.
Anwarior
Guys I am having same problem, the battery used to last two days with mild usage now its only 15 hrs,
statistics show following Apps are eating batery
  1. Android System
  2. Android OS
  3. New User [I have not created any user Account]
  4. Screen
I believe the OS itself is drinking the juice out of battery
has anybody found any solution to it please help, otherwise I'll have to take it back to Kitkat
-Bob-
Since upgrading to Lolipop my Z3 Compact the battery life has more than halved from more than 2 days to 1 day, I like the upgrade but I cant manage the battery loss.
Has anybody found out how to improve it?
Failing that how can I revert back to Kitkat???
-Bob-
Whats  "bleep" bit above?
-Bob-
I've upgraded to Lolipop and although I like the upgrade my battery life has been reduced from 2 days to 1 day.
What can I do to rectify this otherwise how can I revert back to Kitkat?
I cant mangage as it is!
Bandolero
Hi Bob,
I may suggest you to try what
http://talk.sonymobile.com/t5/Xperia-Z2/Battery-drains-faster-with-Lollipop/td-p/957521
Thommo
 You worded - How as hoe
satishbt
Hi all, it's been a week now after updating my z1 to lollipop. Battery drains very fast. I would say is does not stay more than 6 hrs after a full charge and most of the time my Phone is in idle. Please fix this asap.
