My friends, i can see you have many problems with the batery life. I don't know if any of you has noticed this, but when the phone is charging and it reaches 100%, you shouldn't remove the charger. The phone is still charging even after reaching 100%,sometimes for half an hour. If you want to see when the phone is fully charged, go to Settings-About phone-Phone status. In the first field you can find if the phone is or is not fully charged. Try this and let's see what happens. I hope i can help some of you.
My android OS is using most of the battery sometimes more than even the screen.
My phone came bundled with gingerbread and i have updaed and later repaired it again. it does not gives more than 16 hours on norla use.
Any suggestions.. i need it to last atleast a day or more.
JMoerman wrote:
To save battery life:
1. Enable extended standby.
2. Remove/disable any antivirus and taskkillers.
3. Remove the weather widget of your homescreen.
4. Turn brightness down.
5. Charge your phone untill it isn't charging anymore. (100% is not always 100%)
6. If android OS or any other process is using too much battery juice: try a factory reset
Factory reset:
I just lost me apps and their settings, but i recovered them with the backup app.
First make a backup of the apps with the factory backup app.
Optionaly: backup the virtual sdcard of the phone.
Repair the phone with PCC.
restore Whatsapp, etc...
anyone else with battery problems?
After a clean SUS install and remove of McAfee and removed or changed the update frequence of the weather widget I got my old battery cappacity back.
What I do miss is the screenshot function. Can anyone tell me where I can find it?
Simultaneously press the off and the volume down button.
Takes some practice but it works...
Yes,this is right.You can use both hands to be sure you sinchronize good.
This is a normal behaviour? I did all the recomendations mentioned but sometimes battery drains fastly
i think it's normal if you use it oftenly.
It is normal but i recommend removing mcaffee.it drains battery and doesn't help you.
hi.. when is the best time to charge my xperia p? is it when it reaches 30% or when it reaches 1%??
