My friends, i can see you have many problems with the batery life. I don't know if any of you has noticed this, but when the phone is charging and it reaches 100%, you shouldn't remove the charger. The phone is still charging even after reaching 100%,sometimes for half an hour. If you want to see when the phone is fully charged, go to Settings-About phone-Phone status. In the first field you can find if the phone is or is not fully charged. Try this and let's see what happens. I hope i can help some of you.
what the hell happened.... this is after the latest update on my xperia P. the average time on the same usage was 20-24 hours....happy like hell
what update was it? can u tell me that. and did u got some other issues as few ppl say there r few with it
My phone idle uses 21%
Cell standby 26%
Wifi 25%
if i go on the net or let little one view youtube, battery is dead in 30 -60 minutes. Eats the battery.. Pluged into PC companion and says my phone is upto date, also the thing regarding checking battery status mine matches the green logo % charged etc
Any ideas..
my built is 6.1.1.B.1.54 and have'nt faced any bug yet...
The update hasn't arrived to you yet.Where are you from?The new fw acts ok,the phone is more stable than before.
6.1.1.B.1.54 has arrived and i have completed the installation few days back. I see slight improvement in battery performace but defenitely not like what we see from Sumeet
Nothing useful with that.
Problem is screen which uses more battery
as p has brighter display than all smarphone
no new firmware will improve that and as u note charging and discharge rate mainly equal
And no use of using whitemagic for power saving its just bullshit from Japanese inovation
The screen must be on the first place of draining battery,if the os is first the battery goes down extremely fast.You can see this to many users from this forum.And whitemagic is not such a big deal,but it autosets the brightness for what conditions you need.
Good news
Yes,hope the fixes come soon.
