For all those with battery problems,try this and see what happens
profile.country.RO.title
_alexdon_
My friends, i can see you have many problems with the batery life. I don't know if any of you has noticed this, but when the phone is charging and it reaches 100%, you shouldn't remove the charger. The phone is still charging even after reaching 100%,sometimes for half an hour. If you want to see when the phone is fully charged, go to Settings-About phone-Phone status. In the first field you can find if the phone is or is not fully charged. Try this and let's see what happens. I hope i can help some of you.
alexdon
_alexdon_
Yes,it depends if you use the phone while charging or you don't.If you use the phone,it will charge slower in the last 90-100% and until the battery is fully charged it will take more than 30 mins.Also,please tell us if you get a better battery life if the phone is fully charged when removing the charger.
alexdon
205 REPLIES 205
yasinag
I restart my phone after 100% charge to confirm and then disable one process "Unsupported Headset Notifier" using Elixir2 tool. I lost 22% after 20hours moderate use with 30 minutes phone calls.
Please confirm if others also experience similar behaviour.
_alexdon_
you do not need to restart,if you restart the phone will stop charging. i wouldn't use any programs,the battery can do well without any apps.
alexdon
mhaq
You are right alexdon, The phone is still charging even after reaching 100%
But It took morethan an hour to get the FULL Status for me.
_alexdon_
alexdon
mhaq
Yeah, there is improvement in Normal Usage ( Network Data + Phone Calls + GPS + Camera + Walkmen + Videos ),
At 10% it still running, usually the phone will go off around this point.
It's only started, i will update later....
Thankyou for the Tip.
_alexdon_
you are welcome.i would be grateful if a moderator could mark my post as sticky or somehow to let it first in the line because many xperia p users have no idea about this thing,and some of them could improve the battery life.
alexdon
_alexdon_
i can see that not many people are interested in what i had to say.that is ok.then my posts are useless.
alexdon
velkowww
I didn't knew about that, thanks for the tip mate!
priyankar205
I tried that out . My phone takes about 3 hrs to get to full charge.
