Xperia Z2 charging very slowly and the battery emptied quickly
Yasserelmasry
16 REPLIES 16
@Yasserelmasry
If you are using a wall charger and you experience this problem, contact your Local support to get the device inspected
Jake-SonyXperia
Champion
I agree here, 5 days for a full charge is far to long, full charge time is around 2 to 3 hours in normal case use.
Yasserelmasry
Thanks for your help
Jake-SonyXperia
Champion
No problem. Let us know how you get on Slightly_smiling_Face
Yasserelmasry
OK
1fawwaz
Hey Yasserelmasry
I recently had the same problem, but charging takes around 8 hours to full.
What to do? Did you know what was the problem? Have you fixed it?
