Marshmallow 6.0 "Battery usage" icons missing
Dominic81
Hi guys, I dirty-flashed Marsmallow this morning (Flashtool) and everything's working flawlessly so far, except that little bug I noticed:
As you can see in the "Battery usage" screens, the "Screen" and "Cell standby" icons are missing and are replaced by grey rectangles.
Do you notice the same issue?
32 REPLIES 32
profile.country.RO.title
_alexdon_
@92@Dominic81@iSilverBullet guys, this has been escalated. Do not repair or anything.
EDIT: Can you guys please keep one issue per thread? The small apps issue is here:
/t5/Xperia-Z5-Z5-Compact-Z5-Premium/Android-6-0-small-apps-launch-bar-issue/m-p/1101370#M11938
alexdon
Dominic81
Thanks @alexdon
RobertoDS
After a restart, I don't have no more an icon in battery usage !!!
What's wrong with it ?
griever
i wanna ask you guys, why after update to 6.0 my stamina mode gone? is it normal or just me that stamina mode gone btw i using Z5P
RobertoDS
This 3D is for icons missing on battery usage
U can open a 3D why Stamina has gone, here we know it why, but u can open a 3D to talk about that exclusively Slightly_smiling_Face
adamlee2014
Any update regarding this issue? I can confirm a software repair doesn't fix this
Dominic81
It has been escalated to the development team and will probably be fixed in the next update.
http://talk.sonymobile.com/t5/Xperia-Z5-Z5-Compact-Z5-Premium/Marshmallow-6-0-quot-Battery-usage-quo...
profile.country.PH.title
MarlonUk1
azzido
Enthusiast
Hello,
I noticed missing icons when checking my battery stats like beow:
I hope it can be fixed easily.
Thank you.
Rickard
Master
I've received some information on this and the reason they are grey after the update is that this is the standard color used for these icons in Android 6.0 so it's by design. But i've forwarded your feedback about making them more clear.
