- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
euitdebos, what device do you have? dual or single SIM? can you tell us what is your current firmware version after update? Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes please,
I bought Z3 compact D5803 two days ago. I updated to 5.0.2 yesterday and the notification would not be showed when the screen is locked. Should I update something? thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, any news on the upcoming update? It is really annoying that I bought the flagship phone of Sony and I can't use it for daily work....
Sony support, please listen us and fix this issue!
Many thanks in advance
Adrian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a ZR and its very annoying that you removed the icons from the locked screen on lollipop. Why even change that from the beginning? and i don't have active sync... only accounts are google, facebook and whatsapp...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You mean lock screen widgets? Android 5.0 doesn't have lock screen widgets but notifications can work in a similar way to control music for example.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You need to remove the ActiveSync account. To do this, go to Settings -> Accounts -> Exchange AvtiveSync -> [your email address] -> [menu] (3 dots) -> Remove account.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Will this issue being solved for Xperia z3 dual phones (like in the new firmware update for Xperia Z3 phones) within weeks or should I sell my phone and buy another brand??? :(:(
(for me using third party apps is not a solution since I need calendar and phonebook sync too!!! Not only email. )
Regards Adrian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
With our latest software version, you will get lock screen notifications even with an ActiveSync account that enforces a PIN/password. But when you have updated to the new version you need to remove the ActiveSync account and then add it again to enable notifications on the lockscreen.
Z3 Dual will also receive this update but availability of the update depends on local and operator approvals.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for fixing this. Had it not been fixed, I would have gone and gotten another phone. On mine, I couldn't see who was calling me or answer unless I unlocked the screen. Hopefully this fixes that as well.
