Hi
I connected my Xperia Z5 Premium to the Garmin fenix 3 via Bluetooth. It works, but sometimes the fenix 3 will be disconnected. Sometimes it will be connected after a while and sometimes I have to disable and enable bluetooth on my sony.
What could be the problem?
Thank you
+1 with Polar V800 + Z5 Compact.
My previous phone (Z3 Compact) synced fine with my V800.
exactly as my experience from Z3C to Z5C with fenix 3
did you noticed, you cant get the fenix 3 into the smart connect app to manage the actions?
It has also problems to keep the BT connection with other devices (Ford Sync) and the deleted BT devices are lasting in Smart Connect...
Hi!
I've got the same problems with my Z5 connecting to Garmin FR-235
I've tried the suggestions above, but it still disconnects randomly (usually after a few hours, always during the night)
It's very frustrating, please give some advice on what to do?
Lars Erik
Hi!
I've got the same problems with my Z5 Premium but not with my xperia z3 connecting to Garmin Fenix 3
I've tried the suggestions above, but it still disconnects randomly and continuosly!!
It's very frustrating!!!
Help!!!!
It seems like this thread is about the same issue: /t5/Xperia-Z5-Z5-Compact-Z5-Premium/Z5-Bluetooth-turns-it-self-off/m-p/1080649#U1080649
It seems, that the problem is gone. But I don't know why...
Still problems with 235.
It looses bluetooth connection randomly, sometimes after a few minutes, usually after a few hours.
Any ideas?
