Hi all, i just got my z4 tablet from a friend. ive noticed that the battery will be full charge in just about 120mnts or less(using uch10 quickcharge). the problem is, if i disconnect the charger as soon as the battey show 100% or a few mnts after it...the numbers will drop rapidly about a few seconds for 1% untill the value is about 60-70% . ive noticed that when the batt is under 10% it took a long time for it to reach 1% or empty.
But, if i keep on charging it even tho the lvl is already 100%..i usually leave it charge while i sleep. the reading will be normal. is this normal ? or perhaps i should send it for repair? im afraid it might destroy the waterproof seal if i send to sony centre.... i tried to repair using pc companion but the problem still there
Hi @Koey,
The battery level sometimes decreases or increases between 5 and 20% when restarting a device using the software it was originally released with. However, the battery level hasn’t really changed, and over time the battery indicator will be adjusted back to the correct level.
To make sure that the correct battery level is displayed, try these steps one after the other. Check whether the problem was solved after each step, before trying the next one.
If you have followed all the steps I have mentioned then the next thing to do is contact your Local support team to arrange a repair.
hi all, strangely it back to normal since 2 days ago. idk what caused it. last thing i did is i got her a sd card
