T3 camera problem
DavidLim
T3 camera problem
my phone is 3 weeks old.I have problem with my camera ,when I open my camera it said error ,now it said not responding please help me with my problem
17 REPLIES 17
profile.country.RO.title
_alexdon_
Settings-apps-all-camera,force stop and clear data.Restart.
alexdon
If the above doesn't work you might want to repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Phy
Legend
Legend
DavidLim
All of the above, except for the PCC doesn't work
DavidLim
How do I repair with PCC
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
DavidLim
Thx, I'll try later
DavidLim
Btw ,the android process core has stop, what does it mean
_alexdon_
You should perform the software repairad soon as possible.
alexdon
