My phone screen is off or the dark does not work when making outgoing calls
Sria2
My phone screen is off or the dark does not work when making outgoing calls, but I just bought not long ago only 1 week.
12 REPLIES 12
Jake-SonyXperia
Champion
Sorry @Sria2 are you saying your device screen goes black on calls or something else?
Sria2
I do not know, when making a call screen does not work; it goes out or die. I recently experienced this sort
profile.country.RO.title
_alexdon_
@Sria2 The proximity sensor is very sensitive, try to clean it and also make sure there is no screen protector covering it.
alexdon
Sria2
I just used it can tell how?
Emir1
Hero
In addition to what @alexdon said, could you try to see how your device behaves in Diagnostics? Go to Settings > About phone > Diagnostics > Test > Ear proximity. In this test, the device should only vibrate when covering the sensor (located next to the SONY-logo at the top of the front). Does it behave that way?
Also, try to see if the same occurs in safe mode.
Sria2
when I checked there are problems NFC services are not running, as where cope
Emir1
Hero
What do you mean, in a bit more detail? Did you get an NFC error message while performing the Diagnostics test, and if so what did it say more precisely?
Sria2
when performing diagnostics information contained NFC issue is not going well.
Sria2
and when I open the application contained information support NFC services do not operate properly.
