No speed mode on vaio sz6
webustany
hi there
I have a sz61mn/b and can't activate the speed mode. If I shutdown, switch on speed and boot, the light will stay on stamina.
I'm not using the shipped windows vista, but this should be handled by the bios shouldn't it ? (btw, this bios is a shame, you can't configure anything !!! Does sony takes us for dummies ?)
Thanks for your answers
3 REPLIES 3
Blencogo
No this will be handled by the Vaio Notebook Utilities - nothing to do with the BIOS.
Have you reinstalled the Original Vaio Utilities for your model?
Are you using Vista or XP?
:thinking:
webustany
No, I'm using linux...
Why did they didn't put that in the bios ? It would expose the intel card or the nvidia card depending on the switch...
Sony makes for sure good hardware, but they're pure crap at software 🙂
Thanks for the answer though
Blencogo
For Linux have a look here: -
http://moelhave.dk/gnulinux-ubuntu-gutsy-gibbon-710-on-the-sony-vaio-sz6-series/
Under the Stamina vs. Speed Mode it gives a script to switch modes using different xorg.conf files.
:wink:
