Xperia Tipo Dual Proximity Sensor not working (Not Detected)??
ExTaCy1337
Hello guys, I have the Xperia tipo dual. and I have a problem, my proximity sensor is not working or maybe it doesn't exist, some sites says it has but my phone on the *#*#7378423#*#* (This menu or something similar) Proximity sensor says "Not Detected" , Does it have or not? Because if it doesn't I must get a new phone :smileysad:, always in my calls I press buttons, mute the call, and everything, sometimes hang it up, because the screen doesn't go off.
Please help me up 😕
21 REPLIES 21
itisakash
I am also having same problem and i have re-installed the software though it was updated,still having the same problem,what should i do now?
taruntipo
hi i am having a one year old tipo i am facing such provlems too some time my sensor works some time it doesnt when it works it completly locks the phone power button dont even works and when i call some one i cant end the call because the screen stays locked please suggest something
in service test proximy sensor is detected
