Xperia Tipo Dual Proximity Sensor not working (Not Detected)??
ExTaCy1337
Hello guys, I have the Xperia tipo dual. and I have a problem, my proximity sensor is not working or maybe it doesn't exist, some sites says it has but my phone on the *#*#7378423#*#* (This menu or something similar) Proximity sensor says "Not Detected" , Does it have or not? Because if it doesn't I must get a new phone :smileysad:, always in my calls I press buttons, mute the call, and everything, sometimes hang it up, because the screen doesn't go off.
Please help me up 😕
ExTaCy1337
After the new update 11.0.A.6.5 it started working great! Problem solved.
21 REPLIES 21
that's the Service Menu, what does it happen when you test your proximity sensor? post a screenshot
screenshot = press and hold volume down & power for 2 seconds
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
ExTaCy1337
I've already told you but if you want a screenshot ok Dizzy_Face
It says not detected.
Why does this happen?
repair it with SUS if that doesn't do it, then take it to a sony repair center
Update Service (SUS)
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
ExTaCy1337
I've done it and I saw that I made a mistake, when it still says "Not Detected" but when I put my hand over the sensor it says "Detected" XD.
I thought that it says the proximity sensor is not detected on the system.
So now I know the sensor is working whenever I put my hand, but on calls the screen never goes black
What's the problem? 😕
lol, then it does work, when you press those keys while making calls do you keep the phone next/touching your ear or in a pocket?
ExTaCy1337
I've tried covering the sensor with my hands my ear the table my legs, everything the screen doesn't go off it's still on Slightly_frowning_Face but on the service test it says detected when I put my hand 😕
the screen only go off during a call
ExTaCy1337
Yes I know! The problem is that the screen doesn't go off during a call and I press buttons while in call with my ear Slightly_frowning_Face
that's a bit odd. try a different Dialer app from the market. you should take your phone to a Sony repair center.
