Xperia SP -Video recording problem
Mettias
A month after i bought the phone , a message '' Unknown Error'' appears while i trying to record a vedio, each time i found this error i restart the device So i can record vedios normally
Unfortunatly after the latest update ;i can't record vedios any more ,the device hangs for several minutes each time
notes:
  • there is no problem in capturing photos
  • i tried to use app from google store to record vedio ;but with same result :no responce (hangs)
Mettias
well
i tried the following and it works :smileysmileywink:
Settings-apps-all-camera,force stop and clear data.Restart.
2 REPLIES 2
Thommo
Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Mettias
well
