Sometimes my Xperia is slowing down because qosmgr proccess is occupy cpu resource. For what is responsible qosmgr process?
I did a research into the matter and found some information on this subject. Qosmgr its Linux program to manage CPU governor. By default Sony choose 'on demand' governor for its Linux kernel in Android. The qosmgr program takes as a parameter an xml file with the configuration of governor.
root@XperiaJ:/ # qosmgr --help qosmgr XMLFile [--help][--debug][--no_android_log]
That xml file is in /system/etc/qosmgr_rules.xml. More info on:
http://www.indeed.com/r/Amar-Singhal/6992805fa8b03060?sp=0
http://aquosa.sourceforge.net/documentation-description.php
Qosmgr was programmed by Qualcomm, processor manufacturer for Xperia J.
I think this could be related to your network coverage for both Wi-Fi and mobile networks. Please check your network coverage history under settings > power management > battery.
