- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
my xperia sola battery lasts for only 18hrs with minimum or no use.i have noticed in battery usage info that android os drains around 30-50% battery.and after doing some research on xda i came to know that this is a software issue which was also present in xperia s.is there going to be a firmware update for the xperia sola to reslove this issue?.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are you using battery savers or task killers?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a Xperia Sola and also experience the battery drain quickly problem. The problem of my Xperia Sola is that the battery precentage drop quickly from 80% to 69% in 30 minutes. In that period, no wifi, no bluetooth, screen is off, no call making. It is weird. Anyone can help? Is this a problem on Android 4.0.4? How to make the battery last longer?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You need to remove any battery savers,task killers that you have.Also,restart the phone regularly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have no battery saver, live wallpaper, task killer installed in my Xperia Sola.
It is annoying that the battery voltage drops suddenly. I got no ideas to solve the problem.
Will Sony solve this problem completely as I check that many user have the same problem?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I do not know what to say,sola will not receive any more updates.I suggest you try a software repair via SUS:
If it does not help,visit a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've already tried the software repair via SUS but it is no use to solve the problem.
The problem is annoying as it is not consistent. The battery drops 10% in 30 minutes( unacceptable). Or sometimes, the battery drops only 10% in 5 hours( acceptable). I charge my phone to 96% during the night time and use it in the day time. The battery drops few ten % in few hours. How come I can use the phone for one day( ~12 hours) even the phone is in standby mode(wifi OFF, 3G OFF, no making call, no live wallpaper, brightness with lowest setting, BREVIA engine OFF)?
I ALSO do not know what to say as sola will not receive any more updates.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Maybe this is all related to hardware(battery).Visit a sony service and see what they say:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Disappointed for receiving such a solution!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am sorry,it is the best you can do.
