For all those with battery problems,try this and see what happens
profile.country.RO.title
_alexdon_
My friends, i can see you have many problems with the batery life. I don't know if any of you has noticed this, but when the phone is charging and it reaches 100%, you shouldn't remove the charger. The phone is still charging even after reaching 100%,sometimes for half an hour. If you want to see when the phone is fully charged, go to Settings-About phone-Phone status. In the first field you can find if the phone is or is not fully charged. Try this and let's see what happens. I hope i can help some of you.
alexdon
205 REPLIES 205
harimaru
After this update i'm having a huge issue with the battery drain thing. If i put it to charge and after reaching at 100% it says its fully charged , before the update i got a goot batery usage now im afraid to use any app especialy using the camera.
_alexdon_
How much time do you have on the new software?It needs time to settle,the OS,and also about 15-20 charges until it settles.If you have more than 2 weeks on the software,there is a problem with your upgrade,you should repair.
alexdon
harimaru
I couldn' wait so i did a factory-reset/repair, now it seems that its ok. Will see. Before the repair at: power managment - Battery status the graph just went down verticaly i had such an imense battery usage.
My question how to find out what keeps your phone awake, before the reset/repair my phone most of the time was awake.
_alexdon_
You can download CPU Spy from the market,it will tell you when the phone is in deep sleep or when it is awake.
alexdon
VillaYouth
So sorry to seem stupid, but how are you getting to the battery screen that tells you what is using all the power.
I have tried settings/about phone/status which gets me to a screen showing battery status as 'discharging' (which I have taken a screen shot of, but cannot post to this forum, even though I click on 'Insert Image' which does nothing Angry_Face )
But I cant find the page that you all seem to
Ideas ??
Thank you
_alexdon_
Settings-power management(a little battery as an icon).
alexdon
beeelkuuun
well suprisingly for me, battery seems Okay now for me when I updated from 6.1.b.0.544 to .75
manage to get 1 day battery saving (twitter+texting+walkman+youtube and temple run 2) for some few minutes. also I observe I run the radio and keep it playing for 3 hours and it only drains 15 percent.
well I've anage to save my P also for 1 day but just texting and few tweets only.
_alexdon_
Good,i am glad.
alexdon
_alexdon_
before posting about battery problems,check this thread.
alexdon
Sunaj
i have tried with my phone and it work with me.
