After uapdated To Jelly Bean in Sony Xperia P, Album Not working its showing blank.
There are lots of pictuer in my cell which i can browers from file Commander but from ALBUM its blank.
can any one facing same isssue or help me on this?
I've the same problem, the Album app does not show any photo/video. I followed your directions cleaning the cache, it worked for a while then again black! Why?
Clear data,not cache.Search the forum for other posts like yours,someone posted an album app which solves the problem.
Thanks, however I've deleted both cache and data. But nothing solve the problem.
Which App? I do not want use another App. It's enough for me the Xperia P's built-in App.
It is an album app provided by a user.It is an album also,but improved.I will look for the link.
http://talk.sonymobile.com/t5/Xperia-P/Xperia-P-album-gallery-not-opening/m-p/388193#M22027
Check the link above.
If you thanked me,than you are welcome.
I just updated my phone and got the same problem. I cleared everything as the posts said and lost ALL my pictures... now is there a way for me to get them back?
Not a very happy camper.
MrsV
If you did not back up before,you cannot recover them.Why didn't you backup before?Try to use recuva,a program for recovering lost files.
@Marsh-Jariwala wrote:After uapdated To Jelly Bean in Sony Xperia P, Album Not working its showing blank.
after updated ,in my sony experia u dont working ,,like dead condition
