After uapdated To Jelly Bean in Sony Xperia P, Album is Not working. its showing blank.
Marsh-Jariwala
After uapdated To Jelly Bean in Sony Xperia P, Album Not working its showing blank.
There are lots of pictuer in my cell which i can browers from file Commander but from ALBUM its blank.
can any one facing same isssue or help me on this?
44 REPLIES 44
maestralien
I've the same problem, the Album app does not show any photo/video. I followed your directions cleaning the cache, it worked for a while then again black! Why?
Tags (1)
profile.country.RO.title
_alexdon_
Clear data,not cache.Search the forum for other posts like yours,someone posted an album app which solves the problem.
alexdon
maestralien
Thanks, however I've deleted both cache and data. But nothing solve the problem.
Which App? I do not want use another App. It's enough for me the Xperia P's built-in App.
_alexdon_
It is an album app provided by a user.It is an album also,but improved.I will look for the link.
http://talk.sonymobile.com/t5/Xperia-P/Xperia-P-album-gallery-not-opening/m-p/388193#M22027
Check the link above.
alexdon
sam76
Thank u soo much... U t save my 350 Indian rupees
_alexdon_
If you thanked me,than you are welcome.
alexdon
madameverdade
I just updated my phone and got the same problem. I cleared everything as the posts said and lost ALL my pictures... now is there a way for me to get them back?
Not a very happy camper.
MrsV
_alexdon_
If you did not back up before,you cannot recover them.Why didn't you backup before?Try to use recuva,a program for recovering lost files.
alexdon
rithin
rithin
after updated ,in my sony experia u dont working ,,like dead condition
