Everytime when is use the little skip button on a Youtube Video or Netflix the Volume jumps for 1 second high up and then again normal.
This happens everytime i use the skip button or iam looking for my notifications.
So when you Interrupt the sound source for a seconds it jumps high up, like a crack sound.
Pls Sony or Google fix this
Habe das gleiche Problem bei meinem Xperia XZ2 compact.
Zusätzlich ist beim Spielen oft keine klare Soundausgabe, Ton kracht als ob ein Lautsprecher defekt wäre
I have the same problem with my Xperia XZ2 compact.
In addition, there is often no clear sound output when playing, sound crackles as if a loudspeaker were defective
gt
