Z5 Compact Right speaker not work after 7.1.1 (32.4.A.0.160)
Irfanmaruf
I just realized that the right speaker is not working.
I do not know whether this is a hardware or a software issue, as I mostly use earphones before the update._20170703_102715.JPG
Does anyone have the same problem?
CameronT
Champion
@Irfanmaruf,
Sorry I misunderstood, I thought it was happening with earphones too.
Based on the information provided I recommend you contact your Local support team to arrange a repair assessment.
4 REPLIES 4
CameronT
Champion
Hi @Irfanmaruf, welcome to the community. I am sorry to hear about this issue Slightly_frowning_Face
You can test the phone in safe mode and see if the same thing happens. I also recommend you test another set of headphones.
Irfanmaruf
I test it in safe mode, nothing change.
Why i have test another headphone? While the problem is on the speakers.
Heres thhere's the screenshot
I've attached this beforeI've attached this before
 'Stereo speakers right' mean Bottom Speaker on z5 conpact
CameronT
Champion
@Irfanmaruf,
dinarte1111
It happens the same with mine,  the right speaker start to play very low and with noise,  I have a Xperia Z5 Premium.
