Perform software repair with xperia companion once more. If the problem persist. Try to have your device checked atvyiur lical service center http://support.sonymobile.com/global-en/contactUs/
I have no problems with 23.5.a.1.291. It's my second day with that build. And have Stamina!
Hi @ByEc3L,
I am sorry to hear that.
Does it occur with more than one network, or is it only with one specific network that you experience this?
I have the same issue , installed 291 latest and last version via Xperia Companion software repair , it has no result , WiFi is weak in Z3 dual , another device like LG and HUAWEI can connect 1 antenna WiFi but Z3 can't recognise ,they show 6-7 WiFi networks but Z3 shows 2-3 Wifi networks at same place ! device is empty and refreshed after software repair but still has weak Wifi mentioned problem . was it the last software version ? Sony leaved Z3 dual with WiFi problem ? what should we do ?
