xperia ZL microphone issue
sunit1990
I have xperia ZL from past 1 year(now out of warranty).today while making call i realised the other person can not hear anything,but having checked microphone on diagnostics software or while using on other apps like whatapp or even on ok Google it works fine.I am having kitkat 4.4.2 (.230) update.so please help me with the issue.
Is this software issue?
Whether I should repair my phone?
Or there is something else that can be done?
Regards,
Sunit bhatkar
profile.country.RO.title
_alexdon_
Disable microphone noise suppression in call settings.
alexdon
10 REPLIES 10
_alexdon_
alexdon
sunit1990
Thanks alexdon for replying.I hav disabled the same & will try call with this setting.but I hav been using the phone with noise suppression on all the time & there was no issues with calling.so is this software bug?
_alexdon_
I cannot say.you have to check and see how it is.There might be a problem with your SIM.
alexdon
sunit1990
Thanks alexdon disabling noise suppression worked.
Microphone is now working in calls.
I just disabled it nd did restart.hopefully it wont come again!!
_alexdon_
Awesome,keep us updated.
alexdon
PraveenRK
Hi, I faced the same issue but after disabling the "Microphone Noise Suppression" it is now working fine...
But it was suddenly started two weeks ago and no idea why it occured.
srids
i got the same problem with my XPERIA ZL.
enable disbale microphone noice did not help anything.
Person who is on the call cannot hear my voice.
HHG69
I have the same issue too
cdenhond
I have the same problem, please fix this!
