I Just updated my Sony xperia z5 E6653 using xperia pc companion to android build 32.4.A.0.160(android 7.1.1). but after the update the audio is dam low and the eqauilsation is not good and is uneven,for this problem i just reset my device using the same xperia companion,but i didnt solve the issue. i think there is the problem with this update.
and also voLTE option disappeared from mobile networks.
pls resolve this issue as soon as possible.
