like I mention in title... power button in xperia z3+/z4 doesnt work, how can i replace it? theres non one tutorial bout that..
Thanks for help.
If you MUST DIY, here is the info
https://www.ifixit.com/Teardown/Sony+Xperia+Z4+Teardown/47885
Contact your Local support, keep in mind that if you attempt to DIY it will void the warranty
Hi @0slown, welcome to our community!
I'm so sorry to hear about this.
I'm afraid there isn't much to try if the power button isn't working as it should.
I would recommend that you get in contact with your Local support team and they will assist you with having the device sent in to an authorized service centre, just like @uliwooly recommended.
They will happily answer any questions you may have regarding service routines, warranty and so forth!
Let us know how it went!
Thanks mate
No problem at all!
Let me know if there anything else I can assist you with!
Have a great weekend and best of luck with the repair.
