Will I loose the water resistance if I repair my device?
HazemB
Will I lose the water resistance property if I replaced the motherboard in my Xperia™ Z2?
Christofer
Champion
Hi @HazemB,
I do not recommend that you repair the device on your own. Instead, I suggest that you get it repaired by an authorised service center. They can then perform the necessary tests to make sure that the device meets the requirements for it's IP classification after the repair.
You can contact your Local support team for more information on where you can find your nearest authorised service center.
Christofer
Champion
Hi @HazemB,
