WiFi drops when phone in standby
rouleur
Since I have updated my Xperia Z3 Compact to Android 6.01 it looses connection to my home wifi as soon as the phone switches to standby. This is very annoying especially for music streaming. I have tried all the tipps found in the forum on similar issues. WiFi on / off, flightmode on/off, several restarts, reset WiFi settings, start in safe mode, yesterday even reset the phone to factory settings but still have the same problem. The issue is only with the Xperia phone. My partners iPhone as well as my Windows phone stay connected on same network, my Xperia stays connected on other networks as well. Any hint what the issue could be?
rouleur
After full reset to factory settings and new set-up everything works now. In addition problem solved with some bluetooth connections where always had connection problems and akku lasts significantly longer
10 REPLIES 10
profile.country.RO.title
_alexdon_
@rouleur have you checked the wifi sleep policy? Can you set it to always keep wifi on during sleep?
alexdon
rouleur
Yes, is on 'wifi always on'
_alexdon_
Have you also tried out a different router?
alexdon
rouleur
yes, same behaviour 😞
_alexdon_
@rouleur You can only try a software repair using Xperia Companion before you send the device to your Local support.
alexdon
rouleur
ok, will try when find some time tonight. Then rather buy new (no sony) phone...
rouleur
alternatively: is there any way I can reinstall Android 5.x where all worked perfectly fine?
_alexdon_
Yes, you can install LP using flashtool, but your warranty might be broken afterwards.
alexdon
YoGem
Leader
Question, is your wifi router a 5ghz? Do you use Bluetooth devices?
