Stuck in Priority only sound mode, yes it's Marshmallow
stipeCRO
So, Last night I put my Z3 compact to Priority only and this morning I can't switch it off. I tried safe mode and forced restart, nothing helped. It's a 6.0.1
This is the second problem, after problems with Internet on my home WiFi, but somehow, that one solved itself.
profile.country.RO.title
_alexdon_
Have you tried to press volume down to get to silent then volume up?
/t5/Xperia-Z3/Cannot-turn-off-quot-Do-not-disturb-quot/m-p/1137536#M33333
alexdon
5 REPLIES 5
_alexdon_
alexdon
stipeCRO
It stays on
_alexdon_
Have you also checked that topic?
alexdon
stipeCRO
Thanks Alex, that solved it Grinning_Face
_alexdon_
No worries.
alexdon
