Hi guys, I noticed some distrotion sound on the speakers when it are in max volume during on call with audio output active. It will damage the speakers??. it is normal??
@z3compactw, if it's only happening on calls, this indicates that the issue isn't with the speakers. Please give it a try in safe mode and let us know how you get on.
@z3compactw, Try it with other apps on max volume and see if the issue persists, in case it is just call distortion. It's always worth trying the same things in safe mode too.
I use the Walkman and when is on the max volume.It's OK. The question is on Call voice. When it are in audio output on the max volume It get a distortion.
sorry for delay. the speakers work fine. No more distortion. thks
