Bluetooth audio was working fine before the update. After the update: the phone connects to the car stereo unit (I can tell because the car stereo shows phone info (name, battery level, antenna bars, etc.), but when I play audio there is no sound from the car speakers (or the phone). Anyone else seen this? Anything I should try to reset? I tried closing all apps, restarting the phone, and looking in settings for anything that might be affecting the audio routing - but didn't see anything. Thanks.
Hi @tbird20d
Please, from your Home screen try the following:
1. Tap the Application screen icon.
2. Find and tap Settings -> Apps.
3. Swipe to the All tab.
4. Find and tap on Walkman.
5. Tap Force stop -> Clear data.
6. Restart the phone.
I´m at disposal for any question.
Thanks very much. It's working now. I should note that I tried more than what you said, so it might have been one of these other things, but it's working great. The other things I tried were:
Thanks again for the help!
Hi @tbird20d
Glad to read that your porblem was solved, enjoy your Xperia device! I´m at disposal for any question.
The suggestion on that other post didn't worked for you?
