After latest update I noticed a serious deterioration in sound quality. I usually use headset (radio or listening music) the sound is very quiet and cheap quality, and when I get notification, the phone plays the music of notification and the end of this music headset bounced. I have Sony Xperia Z3 compact, I like this phone because it has got a good quality sound and it's gone.
does it happen when you are in safe mode
since you recently upgraded,. try to perform software repair using Xperia Companion
Thank you, that was very helpful!
I could fix my phone!
