Sound problem
Celina99
Sound problem
After latest update I noticed a serious deterioration in sound quality. I usually use headset (radio or listening music) the sound is very quiet and cheap quality, and when I get notification, the phone plays the music of notification and the end of this music headset bounced. I have Sony Xperia Z3 compact, I like this phone because it has got a good quality sound and it's gone.
profile.country.PH.title
MarlonUk1
does it happen when you are in safe mode
since you recently upgraded,. try to perform software repair using Xperia Companion
2 REPLIES 2
MarlonUk1
Celina99
Thank you, that was very helpful!
I could fix my phone!
