Sony Z3 - Internal Storage Problem**** After 6.0.1 Update
funnYD
Dear Sony Team,
After 6.0.1 update, internal storage runs out*** I already deleted everything on my internal storage area, but it is out of storage area.
Here on screenshot you can see, it says that 11.3 Gb Other files*** I deleted all photos, logs etc and I can't see any further files, but it says that internal storage is already full****
I hope you will have a quick solution.
PS: I was the one, who was telling his friends that SONY is the only brand who is checking all details before update of a new software/Operating System version, then releases for users... Now my friends are all really kidding me...
If possible, tell me how to downgrade to latest version***
Kind Regards
Can Kurdi
z3_Storage
funnYD
Dear SONY,
I found out that the application FILE COMMANDER was keeping over 4gb as CACHE*** So, I cleared it and now I have over 8gb for free...
Regards
Can Kurdi
16 REPLIES 16
@funnYD
I can't see the screenshot, upload it to box, drive, dropbox, etc and post the link here or wait
I'm assuming that the screenshot its from
settings > storage?
profile.country.RO.title
_alexdon_
funnYD
Well, it is a clear screenshot via desktop pc; mediaGo screen***
Kind Regards
funnYD
Dear Alexdon,
I read it carefully, but there is no solution***
Kind Regards
funnYD
Also, another important point is, before 6.0.1 update I never had a problem like this... And I did not install any new application etc.
I just take photos and videos*** And I move all to my PC.
Kind Regards
@funnYD
You should the whole thread that @alexdon provided, and if you want, you can share some screenshots
funnYD
There is no solution, yet. And I am not the only one who has that problem***
I hope SONY Team will have a solution.
Regards
Can Kurdi
@funnYD
If you are the only one experiencing and issue, it's probably that there's a problem with your phone.
@funnYD
Just to double check, does your phone has a protective case, film, glass?
have you tested it >>> safe mode
