problem with z5 battery life
aleksa92
i need help... stamina mode is not working properly, my battery is constantly empty..  and my sensor for screen off and on during the call sometimes works sometimes not... 😕  do i change system or??
15 REPLIES 15
@aleksa92
Have you white listed apps such as whatsapp, facebook, messenger, etc?
charge your phone 100% > use it as you normally would > once the battery is at 50% > settings > battery > tap on the battery icon > take screenshots of the graph then tap on the top 4 items and take screenshots
post them all here
also, settings > about phone > status > signal strength > take a screenshot and post it here
aleksa92
how can i post picture? something is wrong... 😕
@aleksa92
scroll to the bottom > tap on FULL or use a computer
NeoBeum
Enthusiast
Clear your system cache by press and hold power and volume up until it vibrates and your screen turns off
aleksa92
ok , is little better... but my stamina mod not working properly,.... i turn on stamina mod and almost all applications
should be stopped , but i continue to recive messages on messenger???!
NeoBeum
Enthusiast
Messenger as in Facebook messenger?
aleksa92
yes.. and other app are still working...
NeoBeum
Enthusiast
Facebook is one of the reasons for drainage
