i need help... stamina mode is not working properly, my battery is constantly empty.. and my sensor for screen off and on during the call sometimes works sometimes not... ๐ do i change system or??
Have you white listed apps such as whatsapp, facebook, messenger, etc?
charge your phone 100% > use it as you normally would > once the battery is at 50% > settings > battery > tap on the battery icon > take screenshots of the graph then tap on the top 4 items and take screenshots
post them all here
also, settings > about phone > status > signal strength > take a screenshot and post it here
how can i post picture? something is wrong... ๐
Clear your system cache by press and hold power and volume up until it vibrates and your screen turns off
ok , is little better... but my stamina mod not working properly,.... i turn on stamina mod and almost all applications
should be stopped , but i continue to recive messages on messenger???!
yes.. and other app are still working...
