Problem with outer border of Font
DatLisi
I have updated to Android 6.0.1 and now nearly every text I type has a black outer border instead of a shadow.
It is really hurting my eyes and giving me headaches. How can I change this? I've tried everything, also third-party applications.
Tags (1)
Jonas
Master
Hi @DatLisi, welcome to our forum!
I'm sorry to hear about that. Slightly_frowning_Face
Could you please specify which phone model that you have? You can find this information in Settings > About phone.
If you could also attach a screenshot of application with the black border I would really appreciate it and it will be easier for me to assist you in the best possible way!
If the font looks a bit thicker, check in Settings > Accessibility > High contrast text and make sure this is turned off.
Keep me updated! Slightly_smiling_Face
3 REPLIES 3
Jonas
Master
DatLisi
I have a Xperia Z2.
Also I figured out what the problem was.
As I updated to Android 6.0.1, my smartphone automatically turned the "experimental contrast" on. I did not realise that and yeay. My problem is solved!
But I really hope my "problem" will help others with the same problem.
I really appreciate the fast response and support. Thank you! Grinning_Face
Jonas
Master
Hello again!
I'm very happy to hear that. Slightly_smiling_Face
I'm sure other members on our forum will find this information very helpful and I'm thankful for telling me that it worked!
Let me know if there is anything else I can assist you with and have a great day! Slightly_smiling_Face
