My phone keeps claiming I need to install a system update. After downloading, the update is stuck in "ready to install" state and there's no way to proceed.
If I go to settings->apps->software-update and clear data, the phone simply re-downloads the update and gets stuck in the same way with the same notification.
I tried setting a schedule to install while charging but the time set passes and nothing happens...
The version of the update is 23.5.A.1.291
The current build number on the phone is 23.5.A.0.575
I was forced to use the companion software to perform the upgrade via USB so the update was finally installed...
I am glad to hear that you were able to resolve it!
