Hi Sony Community,
There are already lots of issues posted here, but so far, I only missed the Stamina mode and Ultra Stamina mode from the previous version. My device is currently running the latest sw update (23.5.A.0.575). A few things I noticed though is that the camera swipe from the lock screen is not always responsive. But what is a bit more annoying now is the LED light notifications.
Before the update (Lollipop), when notifications come in, the LED blinks. I can view the notifications from the lockscreen by double tapping the screen. Without unlocking the phone, and when the screen turns off, the notification lights up and blinks again. But atfter the update to Marshmallow, when the notifications are viewed from the lockscreen without unlocking the phone, when the screen turns off, the LEDs are no longer blinking. maybe Sony changed it? I do not know.
Regards,
kiko66613
In my opinion, this is how it should work. You saw the notifications, they are considered seen. Newer notifications will make LED flash again to know that there are more to check.
@kiko66613 Yes, this is how it works for now, I have checked a Z2 too. And a Z5. I will try to get some info on this.
