Problem with headset with detachable mic
Autumn819
I am using my hyperx cloud 2 headset with my z3 and it work fine. However, when i detach the detachable mic from the headset, the phone does not recognize the headphone any more and when i plug the mic back in it works fine.
Is there any ways to fix it, cause I just want to listen to music and don't want the mic attached.
BTW, the cloud 2 uses a single headset jack (audio&mic).
Rickard
Master
I'm afraid i can't say for sure but it might work if you force the output to the headset using the 3:rd party app SoundAbout from Google Play.
For more information, also see this thread: /t5/Wired-accessories/Hyper-x-cloud-2-headset/m-p/1038373#M925
2 REPLIES 2
CameronT
Champion
Hi @Autumn819,
Welcome to the community.
It is difficult to guarantee full functionality with third party products. In this case I would recommend you contact the manufacturer of the headset.
Just to confirm though, do you experience this issue with any other phone?
Rickard
Master
