My Notification Light is not working. When I receive emails, SMS messages or text messages nothing lights up the Notication Light. Yet it's checked in the display settings. Anyone eise having the same issue?
Why is this phone plagued by so many problems?
Settings > Display > pulse notification light
also its not going to work if you have Stamina mode on
So if the light is not working with stamina mode on I assume it as a bug...
Its not a bug but a way to save battery
@uliwooly wrote:Its not a bug but a way to save battery
Not a bug and not a feature. Not true at all.
I have Z1, you don't, so if you don't know it for sure, why you keep repeating this...?
Never mind. Led WORKS in Stamina mode. Disabling it this way would be pointless. It's a *notification" light.
It should work regardless of Stamina setting. If the option is checked, it should light up while charging (red -> orange -> green cycle) no matter if screen is on or off, and when call/message/whatever is received when the screen is off.No way to see it blinking if the screen is on.
If it doesn't work it's a malfunction or effect of the improperly uninstalled/buggy app managing the notification light.
Easiest way to check if it is a hardware problem is to go to dialpad, enter *#*#7378423#*#*, go to service tests -> LED/illumination. If it works there, it's a third party software problem, not the phone or firmware one.
If it doesn't work on the test, you can try to make a repair via PC Companion or SUS, but if it still doesn't work after that - then you need to return the phone for a repair as you cannot do anything more.
@Achanos mind the Forum guideliness
http://talk.sonymobile.com/t5/Welcome/Discussion-guidelines/m-p/349678#U349678
We are all here to help each other, not to bash on each other, that's for other forums not this one, keep it nice, RESPECTFUL and friendly.
Yes the LED Notofication stops if you use GO Sms. I removed GO Sms LED burns. GO SMS in so kkany ways not compatible withAndroid 7.0
