Notification LED doesn't work after update Android 7
Frank55
Notification LED doesn't work anymore after update Android 7
Has someone an idea?
THX
23 REPLIES 23
Frank55
Yes, you are possibly right
Schnuppl
I have the same problem. After updating to Android 7, the LED will only light when charging.
Frank55
The problem is when messengers are muted, so no notification sound.
If you have a silent notification, put it on and LED will work.
Schnuppl
I want this LED because I do not want to hear any sound.
Frank55
In this thread was a hint from Jildert, there is a notification called silence.mp3, no sound. Just the field notification is filled.
So messenger remain without sound.
Alessio_841
It is a shame that we must install an external .mp3 to correct an issue of Sony!
The worse is that Sony doesn't give us an answer, neither to inform us about the issue's knowledge.
This happens also with Facebook and Twitter.
3dkkm
Totally messy and usually I never login for forum.
I thought that is broke but if I add this code
    Uri soundUri = RingtoneManager.getDefaultUri(RingtoneManager.TYPE_NOTIFICATION);
    mBuilder.setSound(soundUri);
then this is fix. lol ....
Schnuppl
Ad this code?
Alessio_841
Hi @3dkkm,
By adding this code the issue is fixed?
Did you try before?
How to add the code?
Thanks!
Schnuppl
Hello Sony. Is there a solution now? I have reset my z5 compact today again. The notification LED does not flash on any app. (I tried email, whatsap, sms, signal)
Only when i charge the phone the LED-light is on. Please help me.
