Notification LED doesn't work after update Android 7
Frank55
Notification LED doesn't work anymore after update Android 7
Has someone an idea?
THX
23 REPLIES 23
profile.country.PH.title
MarlonUk1
can you try to boot safemode? just long press on the power button
does it work there?>
how about running Xperia Diagnostics. settings>about phone. check if the Led works.
try to perform a software repair using Xperia Companion
Frank55
THX
I try safe boot without success.
The funny thing, LED works when charging and for reminder. LED doesn't work for WhatsApp and Threema.
Xperia companion will be next trial.
nkphnx
On the latest version of WhatsApp from their website, notification light still doesn't work when chats are muted while show notifications.. Notification light will only work if there is vibration or sound. Already checked with WhatsApp.. Now waiting for Sony's response.. Something changed from stock Android 7.0 in Sony's version here.. Sigh....never ending issues with this release
Frank55
Yes, you are right. I did the same experience. If a sound is selected, WhatsApp and Threema are working. If muted, it don't.
Jildert
I haven't tried this myself yet. But if it only doesn't work because you muted. You can set a silence sound for the groupmessages in your whatsapp and unmute those groupapps. Just till there is a better fix.
If you need a sound to test with, I uploaded a 1 second silence.mp3
http://jildert.com/downloads/silence.mp3
ARJUN_SINGH
Try a software repair ....Led light while charging means Light is OK. Must be some issue with settings or Apps.
Frank55
Jildert THX, perfect idea with your silence.mp3
GREAT
Hope, Sony will fix soon
Frank55
Arjun, I tried software repair with Sony companion, without success.
There is a mismatch in Android 7. When muted a chat (WhatsApp or Threema) the LED for notification doesn't work.
With the little trick from Jildert it works.
It seems a must, notification sound has to be set to enable LED
I followed the hint from Jildert and it works.
So DEAR SONY, PLEASE FIX
THX
nkphnx
I think we should all report this directly to our local support to push for a fix. I don't think Sony will care what we say here... It's just too bad their support is going to the gutters alongside bad software..
