Have you tried different to charge the phone with different chargers? Otherwise, I suggest that you open the SIM-card cover > Here you should see an OFF button which you can use the tip of a pen to hold down for 5-10 seconds > When the phone powers off, connect it to the charger and let it charge for 2-3 hours.
Yes I did, but no where in your post I can see that you have used the OFF button. Therefore, why I suggested this.
i have this same problem... no charging when unit is on.
The unit WILL charge when OFF (totally off, not hibernate) but WILL NOT charge when ON in in hibernate mode.
That does not seems right... have you come across a real solution for this
