When did Sony change their statement on using Xperia pruducts under water? They used to say up to 1.5m in depth for a few minutes, now it clearly states do not use under water.
Also noticed this is now the advice for previous products that used to say it was OK to use under water, not just the latest Z5.
Sony products are no longer water proof (what I thought anyway). Watch out!
Before assuming you should read the forum guidelines
http://talk.sonymobile.com/t5/Welcome/Discussion-guidelines/m-p/349678#U349678
Hello,
its confusing that Sony tells that these phones has ( IP65/68) classification. Apparently its IP65, if you read how you can use the phone. If somebody byes and uses it like you use IP68 phone, you dont have any warranty whatsoever.. Now there is theoretical value and practical value and the difference is huge.
Is this same fenomeon thatn with VW-cars?.. in lab you can have different values than in practise.. Thats not good.
I tried that with my Z3C (rip). its fell small distance to sink and the covers opened, it got water inside.. Not included in Warranty. had problems with the covers all the time (4 months).
Is the cover now better in Z5C, even it has still the IP 65 -classification? -in real life..
regards, ricce
Well, the design is a bit different for the Xperia Z5 Compact. For example the USB port doesn't have a flap like the Xperia Z3 Compact. Please visit a retailer to compare the two phones. Regarding the IP classification you can read more about it here: http://www.sonymobile.com/global-en/xperia/technologies/waterproof/
I did some research and my conclusion is, Sony doesn't really want you to use it under water because IP68 is just designed for some accidental situation but not for use it underwater. Also many people's Xperia phones got water damaged because their covers weren't closed tightly before went into water. But still, IP68 is certification so it won't lie. My suggestion is check covers before you use it underwater and do it at your own risk. Xperia devices prevent water from come inside but not prevent water damage like short circuit.
Oh by the way, the pools always have lots of chemical stuff. The sea is always salty so.... you know what I mean. Those stuffs kills every electronic......
@Zacabeb wrote:
advertising the phone as IP68 certified and disclaiming it in the fine print may be illegal in many countries.
Let's put it to the test, shall we?
It is not legal in the UK. If you advertise a red apple and deliver a black grape then small print cannot protect you from the LAW.
Thanks, that helped a bit. I think that Z5 has better sim/memory card cover, than Z3.
I red the waterproof link. There is still a problem:
if you say Z5 is IP68 it means that Sonys claims that device can be in continuous immersion under water.
if Sonys warranty doesnt cover immersion, the classification can be MAX IP66. There is not any other options.
You CANNOT state that classification is IP68 but warranty is not valid if you put device under water.
Other wise you are doing misleading marketing and Sony doesnt do that does it?
regards Klaus
a former owner of drown Z3
(1 inch deep water).
This case is bad for Sony. The bottom line is that Xperia fans are fooled. I planned to replace my Z1C with Z5C, but I'm now seriously reconsidering!
Btw, my Z1C did get some water damage (no salt water) and the local official repair shop didn't even consider any warranty option (my opinion is that the USB cover has a design failure - continuous opening-closing damages the seal etc). The phone still works, but has some flaws.
As a result I have lost my belief in Sony, after many-many years of good experience.
