Battery drains faster with Lollipop
Stenbocken
Has anyone else noticed that the battery drains faster with Lollipop, lasts now 2/3 of the time compered to before upgrade. All battery saving settings are set as before.
Tags (1)
139 REPLIES 139
Ultraman1966
I'm on a Z3, got the 5.1.1 update, still problematic issues with mobile data drain.
Steve_J1
I've actually resorted to keeping stamina mode on permanently and adding a few apps as exceptions (whatsapp and email). Before lollipop I was on 70% by 5pm, after 5.0.2 I managed 40% to 5pm (ran out by the time I went to bed) and now I can get 55%, but I shouldn't have to rely on stamina mode just to get through the day!
Flybler
After the last update, the smartphone's battery began to run out faster. Can't say this clearly, maybe it's my battery, as I use a smartphone for 11 months and the battery began to decrease capacity.
Has anybody observed a similar problem after the last update?
petrikk
same issue here bro..its aronud only 3 days that im update to 5.1.1 xz2 my battery darin too fast as compare to 5.0.2 im also do factery reset but nothing gud is happen ...from days drain drain problems face by sony fans ...but sony isn't hav any sloution
Virgilly1
Since i update to 5.1 lollipop my battery on my z2 is draining down really fast please fix this sony thank u
@Virgilly1
Reinstall 5.1.1 with PCC and report back in couple of days
PC Companion (PCC)
Bridge (for Mac)
waqas1
Hi all
I havr updated my z2 with the recent update of lollipop which had some camera,profiles update.lollipop was going good but since the day i updated lollipop to 5.1 battery is draining too much quicker please tell me how can i downgrade to kittkat or lolliopop 5.0.
@waqas1
Reinstall 5.1.1 with PCC > report back in 2 days.
PC Companion (PCC)
Bridge (for Mac)
waqas1
I want to go to 5.0 not 5.1 again
@waqas1
You should try my suggestion.
if you want to downgrade you have 2 options
contact your local Xperia care
http://support.sonymobile.com/global-en/contactUs/
or
use flashtool
/t5/Xperia-Z2/How-to-manually-update-downgrade-root-2014-Xperias/td-p/593459
