I am having the same issue. I have repaired the phone using PC Companion and it seemed like it had fixed the issue but the next day its now draining the battery again very Fast. Only 17hours in Stamina mode and 9 hours without Stamina mode on. Biggest culprit appears to be the Screen using up the battery even though i have turned brightness all the way down and turn off my Data when i dont use it. I firmly believe this is due to Android Lollipop i have had my phone for 1 year now and this issue occurred right after updating it to Lollipop.
But wont the simple downgrade using basic flashtool ruin or loose DRM keys??
